Error -1073807202, In Serial port RS232
I'm using LabView 7.1 Student Edition and I try to communicate over the serial port. When I run the program examples;
Basic Serial Write and Read.vi or Troubleshooting Serial Line Monitor.vi and so on, (It shipped whit LabView inside the folder examples), always I got Error - 1073807202, I detect that the errors mensage begin in the VISA Configuration Serial Port placed in the Block Diagram.
I'm working in Windowx XP, and I tested my serial port with a null modem DB9 conector, using the Hyper Terminal and It is ok
I checked this error in help file and It writed down about VI_ERROR_LIBRARY_NFOUND.
I couldn't  find the C:\VXIpnp like my older LV 5 version.
Can Somebody give me any suggestions
Message 1 of 11
(6,350 Views)
Eleno wrote:
<cut>
do you have device drivers installed? i had the same problems and fresh
installation of labview and device drivers solved the problem
Message 2 of 11
(6,340 Views)
Hi Joghurt;
I don't know how to get it, I was looking for in the NI site, and I found some drivers under the title,NI-Serial for Windows, Version 1.8 ( https://www.ni.com/en/support/downloads/drivers/download.ni-serial.html), is it ok for solved this problem?
Now I'm reading about it.
Message 3 of 11
(6,330 Views)
What you need to do is install VISA. The VISA driver ships with LabVIEW and is on the Device Drivers CD. Re-run the setup program there to install VISA or you can download the latest version from NI.
Message 4 of 11
(6,326 Views)
What Dennis said is correct.  It sounds like you need the NI-VISA drivers installed.  As he said, you can find them on the device driver CD or on our website at this link.  If you already have VISA installed, you may want to uninstall and reinstall the latest version since something may have gone wrong with the installation.  If this doesn't help, let me know!
Chris R.
Chris R.
Message 5 of 11
(6,321 Views)
Hi,Christ_R
I was reading carefully the install document instructions, It describe three steps, and the third step said; "3.When the installation prompts you to insert the National Instrument Device Drivers CD, click tne CANCEL button, and explain; The LabView 7,1 Student Edition package does not include the National Instrument Devices Drivers CD."
I'll try your sugestion, because I don't have that CD, I just have four Cd;1)LabView Student Edition, 2)Introduction to LabView (interactive Training CD),3)LabView Control Design and Simulation Add-Ons,4)LabView Signal and Image Processin Add-Ons.
Now I'm downloading the VISA drivers from the NI site,I hope I'll solve this problem.
Eleno
Message 6 of 11
(6,309 Views)
Hi Eleno,
When installing LabVIEW, it will automatically prompt you to install drivers via the driver CD.  The student edition of LabVIEW doesn't ship with a driver CD, so you can just cancel out of this to complete the installation of LabVIEW.  You can then just install the drivers separately. You can install the ones you need by downloading and installing them separately and everything should work fine.  Let me know if you have any trouble!  Have a great day!
Chris R.
Chris R.
Message 7 of 11
(6,301 Views)
HI.
I got the same  Error -1073807202 after installing LV 8.0. Where can i download the driver CD for LV 8.0?
I only found the one for the students edition under
Chris_R. ' s Link. - Or does it work in my version too?
Thanks. Luke.
Message 8 of 11
(6,146 Views)
Hi Mogli,
It is best to install the driver versions that come with your version of LabVIEW.  I have just placed the driver CD on the ftp site.  Click that link and a folder called "## Driver CD Dec 05 ##" should have the Dec05 driver CD.  If you have any trouble, let me know.  Files will be cleared from the ftp site occasionally, so if you do not see it, let me know and I will repost it.
Have a great day!
Chris R.
Chris R.
Message 9 of 11
(6,144 Views)
Dear all,
Why I can not download device driver?it is look like the link of ftp is wrong.
Any one can help me?
 thank
Message 10 of 11
(5,681 Views)
