Error -1073807202 occurred at Property Node in VISA Configure Serial Port
I get the message "Error -1073807202 occurred at Property Node in VISA Configure Serial Port", when try to use
the include examples of serial port read/write. or build my own.
Any help is greatly appreciated.
Best Regards
LabView 7.1.1 running on Windows XP
(5,827 Views)
This error codes indicates that you have some missing library code. Try to uninstall and re-install VISA.
(5,814 Views)
DavidT, thank you for your interest.
I working in a full, fresh installation of LabView 7.1.
Also a have installed the 7.1.1 update, but it finnish with
lot's of errors (i attached the log file).
No matters the update is installed or not, i got the same error.
My Windows XP Pro is a spanish version.
Best Regards's
Diego
(5,804 Views)
Diego,
What David had in mind was that you uninstall/reinstall/upgrade NI-VISA, which is driver software that may not have been installed when you installed LabVIEW. Certainly, the 7.1.1 patch would not install this driver.
Check out the How Do I Resolve VISA Error -1073807202 (0xBFFF009E)? KnowledgeBase entry, use its links if appropriate, and follow up if this does not help.
John
(5,799 Views)
I download and install "visa330runtime.exe". The problem is now solucionated.
Thank's to DavidT and Johnner for you kindly and fast help.
Best Regards,
Diego
(5,783 Views)
