Error -1073807253
 What does the Error -1073807253(framing error) indicate?I basically was trying to send data through the serial port via hardware ie a 2051microcontroller+MAX232 IC to the COM port and when i checked it in RS232Analyser i had no problem i could transmit data from my uC and recieved it in the RS232 window. But now when i connect it to the labview program as shown in the screenshot it gives an errorserial read_bd.JPG
(5,519 Views)
 Hi Guest of NI,
Check this for more info about it. And search it in the KnowledgeBase.
TN
Currently using LV 8.5
logo
(5,514 Views)
thx THN but i already mentioned in my post dat it is a framing error...i did run a search for it in the knowledge base as well but couldnt find it...
(5,504 Views)
You should be discussing this in your original thread so people know what's going on and don't have to spend the time providing the same answers that have already been given.
Then you need to look a little harder. There are tons of hits in the forums and on the NI site regarding a framing error
Message Edited by smercurio_fc on 07-29-2009 09:26 AM
(5,486 Views)
