Error 1073807339
Hi there,
I am new to this forum and have had a problem for a few days.
I have the following message:
I work with a Tektronic TBS1072B-EDU > connect by USB.
I'm a newbie in the field.
Do you have an idea ?
(1,582 Views)
Hi TOSADI,
that's the typical TimeOut! error…
Your device is not responding!
Check:
  • Correct device reference (or COM port)
  • correct cabling
  • correct commands for your device
(1,570 Views)
Thanks for your answer.
Here is what I have already done:
I changed the USB cable >  Same.
I disabled the energy saving of usb ports > same.
The fault occurs after 5-10 minutes.
FYI the use is for testing the capacitance of motors.
(1,560 Views)
Hi Tosadi,
Perfect!
So there still is the possibility of invalid commands which are sent by you to the device…
Did you try to debug which command enforces that Timeout response?
(1,546 Views)
