Error -1073807343 when taking picture of front panel
Attached vi works fine to take a picture of the front panel, but when I try to duplicate the same code on a different VI, I got the error: Error -1073807343
VISA:  (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
The code that I try to use in a different VI is attached:  Take front panel picture -Block Diagram.gif
(2,747 Views)
Accepted by topic author frn
Your VI is working well.
I dont think so that this VI is causing the issue
VISA Error occures due to some other reasons explained here.
Also please check the error cluster is passed properly through this VI ( if you are using it as a subVI)
(2,716 Views)
Thanks ManLD,
It was something else not related to this issue.
(2,702 Views)
