03-20-2009 02:56 AM
I am using Labview 8.6 along with the Simulation interface toolkit for interfacing labview and simulink.
Our system setup is as follows:
We are using a ZigBee node (provided by TI - ez430 rf2480), connected to the USB port of the computer. The Labview GUI reads information from the USB using VISA and sends this to simulink. Simulink performs some computation and sends back resulting values which are sent on air using the ZigBee.
Recently, while running the simulation, I am encountering Error -1073807360 in VISA, it sometimes works fine but many times gets stuck at this error. Can someone please help me regarding this and possible cause of this error encountered.
03-20-2009 03:09 AM - edited 03-20-2009 03:10 AM
Always do a search in the forum first and post if you have queries that are not solved. Since you are a beginner am telling this. Once you get used to it in forums, you will learn a lot.
search here as a start. Post back if still you have problems.
Enjoy Wiring.
Mathan
