Error -1074001656
Hi
I have updated the version of the CMU200 to V4.2 I have also updated the cmu-k53 BT option to V4.2 as well I used the links you sent me yesterday.
My lab view drivers were downloaded today from your website Still a lot of errors Help needed ASAP For your convenientI am working with Lab view 7.1 And I attached the .llb for you to run it yourself Thanks Shai
Error -1074001656 occurred at RSCMUBT_Init_BT_Sig.vi
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
(3,266 Views)
This error has been brought up previously here on the discussion forums, the link is below.
http://forums.ni.com/ni/board/message?board.id=140&message.id=2802&requireLogin=False
Also the driver for the CMU-200 is not supported by National Instruments, below is the link to the driver from the manufacturer
http://www.rohde-schwarz.com/www/dev_center.nsf/frameset?OpenAgent&website=com&navig=/www/dev_center.nsf/html/nav,10,11&content=http://www.rohde-schwarz.com/drivers/overview.html
If neither one of those links is able to resolve the issue please tell me a little more about what GPIB device you are using from NI along with what version of NI-VISA you have and a about your application.  Thank You!
Daryl Ellis
(3,242 Views)
hi Daryel,
I am using CMU200 it has base version v4.20 and bluetooth versiov CMU-K53 V4.20 as well (I have already checked with R&S and these are the lateset ones)
my CMU config for a secondary adress BT Sig at adress 1 and BT NSig at adress 2.
I have downloaded rscmu2bt_lv7_4_00_00 and  rscmu200_lv7_3_80_1 from R&S website and they seems to be the newest oens
any ideas???
(3,228 Views)
Duplicate Post
Adam Wooderson
(3,218 Views)
