Error -1074118654
I am using USRP as a receiver but it returns with an error i.e. "Error -1074118654 occured at niUSRP Fetch RxData (CDB Cluster).vi"
Kindly some one explain how to fix this issue, Thanks in advance...
Regards
(3,386 Views)
can you please explain us what you try to do and attach some VI's? When does this error occur?
Cheers,
Philip
(3,371 Views)
Dear Philip,
Many thanks for your kind response, the issue has been sloved but I hope you can guide me in one another issue that is using USRP as a transmitter, it works fine but when I turn on the HIGHLIGHT EXECUTION button there I saw an error i.e. ERR-1074118645 after niUSRP Write Data Tx.vi
Kindly check the attachment for .vi file
Kind Regards
(3,363 Views)
usually the highlight modus is not working properly with hardware. If you try to read the buffer in highlight modus the old values have been overwritten by new ones. This happens because the programm runs to slow. The error should mean that you are missing/losing data.
Cheers
(3,356 Views)
