Error-1074126845 ocurred at tktds1k2k Read Waveform.vi (Hex 0xBFFA2003)
I am trying to controll an socilloscope Tektronix 2024B by using a labview program. The oscilloscope is connected to the PC via USB, and the Measurements and Automation Expolorer indicates that the devices works properly (I can actually controll the oscilloscope by using Signal express, and this works perfectly, meaning that the comunication between the computer and the device is okey). The thing is that I want to use a labview program since I want to take simulatneously measurements with the oscilloscope and other devices which are alredy controlled via labview programs.
I have download the dirvers tktds1k2k from ni.com. The application tkds1k2k SWL Example.vi works properly. However the application tkds1k2k Getting Started.vi, gives me an the error Error-1074126845 ocurred at tktds1k2k Read Waveform.vi, Driver status (Hex 0xBFFA2003). Apparently the devices is correctly iniciallized, the trigger is ok but when it gets  Read Weveform.vi, an error occurs.
Do you know what is the problem or what I could do to try to find it out?
Thank you in advance!
(2,798 Views)
Go through all the links in this search and post if you still have problems.
Mathan
(2,785 Views)
