Error -1074395397 occurred at IMAQ InverseFFT
I have a problem in my VI. I can't get an image result after pressing the button for IFFT even though I initialized it as a complex image. Still it says in the error that it requires a complex image. Thanks for helping.
(3,439 Views)
Accepted by topic author nerudorin
I think have suggested in your other thread try to use state machine.
Coming to your problem here:
-After you press FFT, in the second iteration where FFT is false which image you are passing?
Spoiler
Image 1(which is grayscale and resides int the wire ref)
-You can avoid this by properly using shift registers and retain the Complex image.
uday
(3,416 Views)
