Error -1074396006 video compression problem
I am facing problem in saving the video in a compressed format.
I am getting the following problem (image attached).
Please help me in saving the video in any compressed format.
(3,456 Views)
The Get Codec Names returns you a string of the Codec Names (as the function name implies) that are installed on your PC (read the Help message for this function).  You need to wire one of these strings (not a string consisting of a concatenation of all of them) to the AVI2 Create function.
(3,419 Views)
Hi bob,
I started with the same only but I was unable to wire directly from Get Codec Names to AVI2 Create function. I was getting the following error, if you don't mind can you update my vi code and send it back to me.
(3,411 Views)
