Error -1074396120
I have attached a code to find feature detection and matching in images. I am getting output of intermediate stages but not getting final output. I am getting error  as: Error -1074396120 occurred at IMAQ Overlay Lines
trial stitching.vi is the main program
Other are sub vi's
(3,035 Views)
You are extremely stingy with details!  Did your Error Message tell you which VI had the Error?  Is this something that you think we might find helpful?  Do you know what this Error Message means?  Did you try to isolate the particular function that failed?  Did you put probes on its inputs to be sure the function had valid inputs?
This is your problem and your VI, running your data.  Provide us more data, and do a little more investigation on your own.  Do you know how to use Probes?
Bob Schor
(3,000 Views)
