Error -1074397153 Cannot detect recognizable video source
Recently upgraded from LV 8.0 to LV 2010, and upgraded DAQmx to current version.  Now my video data acquisition program doesn't work.  I get the message
Error -1074397153 NI-IMAQ: Cannot detect recognizable video source.
I get the same error message when I try some of the example IMAQ VIs that ship with LV 2010.  I am using a NI PCI-1411 image acquisiton card.  I have tried replacing the S-video-to-S-video cable.  I have tried swapping PCI-1411 boards with another machine.  I have tried different video sources: 2 medical ultrasound machines and 2 VCRs.  I have tried the S-video outputs from the various sources, and I have tried using the RCA plug video signal, with a converter to S-video type plug at the PCI-1411 end. I have checked in MAX to confirm that the 1411 board is recognized and is img0.  It is.  I have run the MAX self test on the 1411 board; it passes all tests.  Thank you for your suggestions.
Bill
(2,850 Views)
Accepted by topic author WCR
It sounds like you need to upgrade the NI-IMAQ drivers. What version are you using?  Try taking a look at this KB to verify if you have a compatible version of NI-IMAQ/dx installed.
NI-IMAQ and NI-IMAQdx Compatibility with Different LabVIEW Versions
http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument
(2,841 Views)
