Error 10800 by AO Control.vi
I've installed Labview Professional v.6.0 in my computer. When I execute the examples about DAQ (I have an AT-AO-10 card installed and configurated by MAX), I always receive 10800 error located in AO COntrol. What can I do?
(2,854 Views)
Can you tell me of an example in DAQ that gives you this error?
Mark
(2,854 Views)
Hi Mark! I wanted to use in my application AO Waveform Gen.vi, but I always get the same error, 10001 by AO Group Config and 10008 AO Buffer Write, so I decided to try with the simpliest one, Generate Continuous Sinewave.vi from the examples library, and here it's where I get the 10800. I'd appreciate any help with this, I'm a student trying to finish her master, and I only have 3 weeks more. Thanks.
(2,854 Views)
I think that an AT-AO-10 is not a buffering card, meaning it cannot output a buffer. You have to update the channels one at a time.
I've looked it up in the NI catalog, and it does not show any output rate, so I believe it can't do an output such as the continuous sinewave VI or Waveform Gen VI creates. You'll have to output each one with AO Single Point VI or similar.
Mark
(2,854 Views)
