Error 1090 : Specified object cannot be moved.
Dear All,
I am using the property nodes "Position" for rearranging my interface during execution, for example moving a table depending on the number of elements.
This used to work well but for some reason from today I get the error 1090: "Specified object cannot be moved.".
Of course, I do not realize what I changed that produces this effect... The table concerned by this error is not position locked. It is located in a tab control but I do not try to move it out of the tab control boundaries...
What could be a reason for preventing an object from being moved ?
Regards
(3,029 Views)
Accepted by topic author MaximeD
Okay, just found why : The table itself is not locked but the tab control in which the table is located is position locked. That caused the error.
(3,023 Views)
