Error 1097 Call Library Node
Hello everyone.
For my Bachelors thesis i was tasked to do a few measurements with a photogoniometer.
All the programs where used before and worked as they should. Since then, the system got updated from Windows 7 to Windows 10 and the LabVIEW Version got updated from LabVIEW 2011 to LabVIEW 2019.
When I tried to start the program I encountered a few errors.
One of them was the Error 1097 regarding the Call Library Node.
I am not very knowledgable with LabVIEW, so it is hard for me to trouble shoot the problem by myself. I attached the DLL and the part of the program, where the error is.
Thank you very much in advance.
(2,439 Views)
Hi Trimar, It would be helpful if you could locate the document that describes SMCDLL.DLL.
Is the model# of the device similar to "SMC-1000"? Web searching using the model number may help locate the document (for smcdll.dll) online.
The error 1097 is typically caused by wrong parameter configuration in the Call Library Function. There should be a document describing the parameters required by "smcdll.dll).
Cheers!
(2,347 Views)
