Error 1097 occurred at Call Library Function Node in ASDK.lvlib:asdk Send.vi->SPGD_flat_Alpao97_dx.vi
We use the DM produced by Alpao, their ASDK worked well before. However, the program got this error today
(1,873 Views)
Maybe you can try to check the calling convention, make sure you have the correct winapi or c convention in the call library node. You may refer to the following article : Error 1097 Occurred at Call Library Function Node
(1,772 Views)
(1,772 Views)
Hi Dr. Marinre,
I have the same problem. This library used to work, but I upgraded to Windows 10 and now I'm getting this error.
Did you get a solution to this problem?
(1,553 Views)
