Error 1097 occurred at call library function node in niDCPower Initialize with Channels
Hi all,
I am trying to install LabView on another laptop to run my program. The program itself has no error when it is running on current laptop. However, I kept getting this error on the other laptop. I wonder if I missed any packages or drivers, which caused this problem.
I have tried to reinstall the whole LabView program, repairing DC drivers and DMM drivers on NI Package Manager.
I wonder if anyone here faced this problem before. Please help!
(113 Views)
Sounds like a driver issue to me but I could be mistaken.
1.) Read this Error 1097 Occurred at Call Library Function Node - NI
2.) Try: Open Run LabVIEW and as an Administrator and try re-running your program.
3.) Try: Running an example VI that utilizes the hardware (Help->find Examples)
4.) When you have Labview open got to -> Help -> About Labview.. note the version. Open NI-MAX and ensure the drivers and version are the same on both the laptop and the NI Hardware.
(81 Views)
