Error 1097 while calling C++ DLL
Hi all,
I have created a C++ DLL for Labview, but it generates error 1097 for this part of code mgr.Open() and after that, below is my code
it works fine in visual studio.
#include "FpgaManager.h"
#include <iostream>
namespace fpgamgr = enclustra::fpgamanager;
int main()
fpgamgr::FpgaManager mgr(fpgamgr::types::ApiUrl:: FX3Default());
std::cout << "FPGA Manager Version: " << mgr.Details() << std::endl;
auto& mm = mgr.CreateMemoryMap(0);
mgr.Open();
std::cout << "Register: " << std::hex << mm.ReadRegister(0x10001000) << std::endl;
return 0;
Tushar
(1,500 Views)
The Call Library Node only can call exported standard C functions. It can not know about C++ object pointers nor any of the C++ object data types.
There are not only to many of them that the Call Library Node ever could support them, but the exact implementation of these things is compiler specific.
You need to write a wrapper DLL, that calls the C++ methods and exports standard C compatible functions with standard C compatible parameters.
Rolf Kalbermatter  My Blog
(1,491 Views)
Hello Rolf Kalbermatter,
I will try it , thanks
Tushar
(1,457 Views)
I have written a wrapper but still i'am not getting it , below is my code it cause error whenever i add mgr.open()
Tushar
(1,402 Views)
