Error 1172-Newport DL225 delay line
Dear Sir/Madam
We are trying to interface the instrument through labview using the files given on the site.
Every time we run the files we are facing the error Error 1172 - Invoke Node Error calling method CommandInterfaceDLS.DLS.DBH in DLS-Unified.lvlib:LWDLS_DBH_Get.vi for each of the file that we run. I request you to give some solution for this error.
For more information I would like to say that, we are using Labview 2016 version and Windows 7, 64 bit with .NET Framework version 4.7
(2,853 Views)
malay@iiserb.india wrote:
Dear Sir/Madam
Was there any solution you found ? We are trying to do the same thing, thank you so much for your help.
(1,110 Views)
The .Net assembly called by this driver has generated a .Net exception. LabVIEW itself has no information what was the actual problem but the error message should contain some error text reported by the .Net exception that would give more information (if the assembly was programmed right, it may also just prefer to throw a generic exception without caring to tell what might be the actual problem).
It's definitely an error in the assembly so we can't help you much further. It is something you have to take up with Newport support.
Rolf Kalbermatter  My Blog
(1,091 Views)
