Error 1172 occured at invoke node
Hello
I am new to Labview and object oriented programming. I have an already written c# code which communicates with a digital I/O card attached to a test system. I want to run those c# functions in labview. I am using .NET constructor pallett and then invoke node but I am receiving following Error:
Error 1172 occurred at Invoke Node Error calling method DmmCSharp.Handler.Reset, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
    Inner Exception: System.Runtime.InteropServices.COMException: KtMDsr: A connection to the instrument has not been established.)
Image file of error and vi file is attached below.
(5,875 Views)
(5,851 Views)
