Error -1223
Hello!
I am very new to both Labview and interfacing with external devices, but I'm trying my best! I am trying to work with a Signal Recovery 7265 DPS Lock-in Amplifier, using a GPIB-USB-HS cable. I've installed both the drivers for the amplifier to communicate with windows as well as the drivers for Labview to communicate with the Amplifier. There is a small tutorial included in the Amplifier driver documentation that I have been following. Unfortunately, I have run into the error code: -1223, and have not been able to find a solution.
In my program I checked the VISA session, which is set up  to GPIB::12, which is the GPIB address on the Amplifier. The Amplifier shows up in NI MAX, however, querying the device returns errors in both write and read.
I have been looking through documentation, and forums for quite some time and couldn't find any solutions, any help would be greatly appreciated.
(3,944 Views)
I'm not sure you are using the correct VISA Session.  It should be GPIB0::12::INSTR.  Further, I don't see in your code where you are setting the VISA session to use.  Have you tried communicating with your device through MAX?
(3,925 Views)
Can you post a screenshot of how it looks in NI-MAX?
If you go into NI-MAX and select the device, is there an option to "Open VISA test panel" at the top of the screen, and if so, can you open that, go to the "Input/Output" selection, select the "*IDN?\n" option (it's probably the default) and then press "Query" and see if you get a response?
The error you're getting is one you might see if the device isn't communicating at all, or if it is but the string it returns in response to the *IDN?\n query is not what it expects.
(3,918 Views)
Thank you for your reply!
I have attached a screenshot. It seems that I cannot write to nor read from the device. Although I don't know why, which therein might be my issue.
(3,913 Views)
Accepted by topic author YacobD
The GPIB-USB-HS should not be used as a raw USB device.  You probably need to install NI-488.2.
(3,904 Views)
