Error 128 - open connection limit exeeded
I too, have this error 128 - open connection limit exceeded. So far, the only thing I can do to remedy it is to restart the application. Unfortunately, restarting causes a major disruption in the workflow.
I am using a webservice, through a proxy. The webservice is not made with labview.
Any suggestions on what I can do about it?
(3,357 Views)
aartjan,
I presume you can do some error handling and retry the connection?
All the best,
(3,312 Views)
You got any solution to this?? Using close connection in client doesnt close the connection it seems. I am able to connect and reconnect to a running server around 1018 times. After that it throws, error code 128. I tried to handle the error by closing the connection and re opening, still doesnt work.
(2,487 Views)
