Error 13 in Save Library for Previous
I always get error 13 when I run this.
Has anyone used this successfully?
(1,073 Views)
For me it works.
Make sure that:
 - the "Path" parameter is a folder path, not a file path;
 - the "Version" parameter has a value in the same format as when you manually "Save for Previous Version..." (e.g. "19.0");
Otherwise, is it a special kind of library (XNode, XControl)?
Is it possible that your library has missing dependencies or that the dependencies have no equivalent in the previous version?
Raphaël.
(1,069 Views)
It turns out that Error 13:
Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format.
Shareable board exclusively owned.
Really means:
Hey doofus: You can't overwrite a library file with a previous version!  (Use a different folder!!)
(1,038 Views)
