Error 1320 when trying to make a caption visible in LV 71
If you try to make a caption visible of a new control via a property node you will get error 1320
(LabVIEW: In edit mode, LabVIEW cannot return a property for a control part that you have not yet created)
WHY?? In LV 7 it does work, and in 7.1 it doesn't�.
Kind regards,
(4,947 Views)
I discovered this problem not too long ago.
Follow the discussion here for the whole story.
The work around is to first manually make the Caption visible by right clicking and navigate to Visible Items >>Caption. It seems in 7.1, the Caption is not created until you first turn it on manually.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(4,948 Views)
Thank's,
But your link (here) doesn't work…and I am interested in the whole story.
Kind regards,
(4,921 Views)
Here's the new link.
http://forums.ni.com/ni/board/message?board.id=170&message.id=94750#M94750
The other link was to the old forum.
Ed
(4,917 Views)
Thanks again....
(4,912 Views)
