Error 1334, missing file from within .cab
Hi there, I hope someone can help.
For an application that has been maintainted over a number of years, I have encountered an issue where the installer generates an Error1334 which is indicating that a file is missing from a .cab file. Sometimes you can hit continue and proceed with the installer and the application will work fine, other times the installer fails. I don't have too much information on how the install fails, sorry. I'm getting second hand information and I haven't yet managed to replicate the install failure. I can get the Error 1334, but can hit continue and install.
I am attempting to clear this error in the hope it is the source of the issue.
If I search in the installer files for the indicated "LVRTL00.cab" I get several entries. Opening each of them up in WinRar I cannot find the named file, so I don't believe it is being created by the application builder.
The error message refers to a Real-time module, which I believe I shouldn't be needing since it's a software application, not an embedded one. Labview is adding a lot additional installers making the installer volume 2-3Gb+! Over time, the incremental updates to Labview have added more and more installer modules due to the dependancies enforced by NI. Aside from core components I mainly need NIDAQmx, NIMAQdx, VISA (for RS232), NI Shared variables and configuration support in NIMAX. I can be more specific about what installers are included if that would be helpful.
If someone could explain why when I run the installer it is calling for a Real-time module, without me asking for it in the builder, I would be very grateful!
I did try installing the real-time module, but I don't think my license covers that. (Mine is just core dev. + Vision acquisition)
I did try this, no effect:
http://digital.ni.com/public.nsf/allkb/577B98C168E61C1386256D09005DDCC8
I am building this in LV 2015, and I have installed LV2017, with updates. I have also compiled this on LV2017 and got the same error.
Apologies if have not worded this very well or not provided enough detail, I wasn't sure where to start. Happy to provide what details I can.
Kind regards,
David
(3,994 Views)
Okay, so in case this is useful to someone else, I'll post an update.
I seem to have found what causes the installer generate the error. I had rolled back the build spec. for my installer so that it is only installing runtime libraries and this was ok. For my application I have been relying on using NIMAX to configure devices on the target system, and I would prefer to keep it that way. So, I have been enabling the configuration support for each module I use one by one, building an installer and then trying it out.
Turns out that I can install IMAQdx Runtime 16.0 with no problem but using NI-IMAQdx 16.0 generates the 1334 error. I did try an installer with all the dependancies that NI-IMAQdx 16.0 would add, but without the module itself. That one did not generate an error either.
I can probably work around this, making the camera configuration in my application rather than NIMAX, bit of a pain though.
I assume that NI-IMAQdx is somehow referencing something from the Real-time module, telling the installer it has a file to include but since I do not have it installed it cannot add the file to the build. Maybe errors are not being reported correctly at installer complie time, if I can create an installer that is referencing a file it does not have.
I had a 5 minute search for an appropriate way to report this bug on the labview site, but I didn't find anything obvious so I'm going to leave it here. If anyone reads this, any suggestion would be great, thanks.
(3,946 Views)
Hi David
Thank you very very much for posting the solution to your problem!
I have been facing the exact same issue for the past couple of days. The application runs fine if I continued with the installation after this error comes up.
I have added IMAQdx and IMAQ to the installer which earlier had only the run time engines.
I will go ahead and remove them and try the new installer. I am hoping that I would face no more such errors!
Regards
Freelance_LV
TestAutomation Consultant
(3,604 Views)
