Error 14 ocurred at GPIB write, labview cant add resource
I am using LabView 2009 to control a research system contains Lakeshore 331S and Keithely 2425, it was work probably , but recently I am receivng an error message:
Error 14 ocurred at GBIB write, LabView cant add resource
Message 1 of 14
(7,262 Views)
Not really clear: was it working, and has suddenly stopped?
Did you make any HW/SW modification on your system?
Message 2 of 14
(7,249 Views)
Error 14 does not mean "LabVIEW cannot add resource" in your case. You should have nticed that it says "possible reason(s)" and it says "NI-488:  GPIB bus error." Check your cables and try with a different set of instruments.
Message 3 of 14
(7,241 Views)
you are right , the message says: possible reason(s)" and it says "NI-488:  GPIB bus error."
I have checked the cables and I examined the connections with sending a command, it was received successfully by Lackeshore 331S through (measurement and automation explorer, version 4.6.1).
Message 4 of 14
(7,226 Views)
Hello baalbiss,
Which version of the 488.2 driver do you have installed?  Just to confirm, you are able to communicate with the instrument through MAX, but not through LabVIEW?  Did you recently upgrade to LabVIEW 2009?
Ryan T
Message 5 of 14
(7,197 Views)
Hi Ryan T,
The version is 4.6.1
 I am able to communicate with the instrument through MAX, but not through LabVIEW ,also I created  execution files for the same VI's and they communicate with the instruments but with other PC
If you could send to me how I can make the upgrade to labview 2009.
Message 6 of 14
(7,175 Views)
Hi
The version of 488.2 software is 2.71
thanks
Message 7 of 14
(7,172 Views)
The error often indicates a hardware problem. Have you tried replacing the cables or only having a single instrument connected? You say you communicated to the Lakeshore but don't mention the Keithley. Exactly where in your code does the error occur? During a write? During a read? For which instrument?
Message 8 of 14
(7,156 Views)
Hi
The error occurred at GPIB write. The problem with the both instrument (Keithley and Lakeshore) connected at the same time with the PC, about the cables I have checked them by testing the connection with MAX, and sending commands through it.
Message 9 of 14
(7,149 Views)
Hi baalbiss,
What GPIB address are you sending into the GPIB Write function?
Ryan T
Message 10 of 14
(7,119 Views)
