Error 15 at "Run VI" Invoke Node When Building a LabVIEW Executable
I am trying to run a vi by using the "run VI" method of the invoke node. The source code works perfect. However, I cannot run the vi when I use the executable version. Specifically, I get the Error code 15 at the "error out" output of the invoke node while using the executable version. Why is this occuring?
(4,233 Views)
Hello ameng,
This behavior is typically the result of trying to call VI that has had its front panel removed. The KnowledgeBase linked below has more information on this issue.
Error 1 or 15 Opening Dynamic VI from LabVIEW Application
Please let me know if you have any other questions about this issue.
Matt F
(4,213 Views)
Matt, the link does not work.
(2,120 Views)
Hi namascar,
Because you answered in a 16 year old thread.
(NI's website was redesigned several times in between…)
(2,113 Views)
