Error 1502 during build with Sound & Measurement toolkit VIs
I get error 1502 - A VI broke during the build process when I build exe. My project uses Sound and Vibration toolkit VIs. The problem could be replicated by just trying to build an exe with NI example VI (I used Continuous Swept-Sine Measurements (DAQmx).vi). I tried enabling debugging as suggested by error description and the build was successful, but the exe was not in running state.
Has anyone got any fixes for the issue?
(3,868 Views)
First ,Make sure you have all dependent dll's and files required are included in your build. What version are you using? Fix the broken VI. The Details block can give more info.
(3,827 Views)
Dave,
I have included all the dependent files. I see no error when I generate a preview in build spec. I use LabVIEW 2016 and sound and vibration toolkit 16.0. The vi is not actually broken but the error message says it got broken during the huik
(3,818 Views)
Dave,
I have included all the dependent files. I see no error when I generate a preview in build spec. I use LabVIEW 2016 and sound and vibration toolkit 16.0. The vi is not actually broken but the error message says it got broken during the build process.
(3,817 Views)
Not Sure then. Do you need a License filoe for the tool kit to create executables? I have never used the sound and vibration add on.  But I would check the requirements of that add on.
(3,811 Views)
