Error 1585 occured at Get LV Class Default Value.vi
Hi
I get unfamilliar error when trying to load a class in runtime when using "Get LV Class Default Value.vi"  like the image further below.
Labview returns the following error:
Error 1585
Description:  The class library is loaded, but its datatype is not ready to be instantiated.
What could cause such error? Anyone has seen this before?
And it happens first time it is executed after a fresh labview startup. Second time it will not show up.
I'm running labview 2013 in Redhat Linux environment,.
(3,650 Views)
How is the lvclass implemented?
//Klabbe
(3,553 Views)
I have the same problem.
Any suggestion about the possible causes and solutions?
Thanks in advance,
Marco
(3,053 Views)
