Error 1722 during LabVIEW installation on Multipoint Server
I am installing LabVIEW 2012 on a Multipoint Server and get multiple Error 1722 errors. Has anyone installed LabVIEW on Multipoint Server? Is there a setting that needs to be changed? or a configuration setting that needs to be set?
(3,225 Views)
Hello Friedmanfr,
Error 1722 seems to be a Windows error message. I did some digging and it seems like this Microsoft KB could be useful to you: http://support.microsoft.com/kb/829359
The KB is for Windows Server 2003, but might be relevant to Multipoint as well. If you can provide more details about your issue, I might be able to help you further.
Do you know at what point in the LabVIEW install, these errors occur?
What are you installing LabVIEW 2012 from? DVD? Downloader?
What steps did you take during your install leading up to the point these errors occur?
With servers, it could be that you have permission or network connection issues. Do you have any information on these configurations?
Wan L
http://www.ni.com/support
(3,196 Views)
