02-07-2012
06:48 AM
- last edited on
06-26-2026
08:53 AM
by
Content Cleaner
I am unable to install the necessary LabView Run-Time Engine 6.0 required to run my VitalView Software. I have reviewed the message boards and attempted all possible solutions: disabling anti-virus programs, following the NI support links: http://digital.ni.com/public.nsf/websearch/334E91287EDEA75286256D9B003A947A?OpenDocument .
None of these methods will allow for the Run-Time engine to be installed. What can I do?
Help very much appreciated, thank you!
02-07-2012 07:44 AM - edited 02-07-2012 07:46 AM
And what is your OS ? Windows 98 / XP / Vista / 7 / Linux ? 32 / 64 bit ?
Just remember that 6.0 is a very old version of LabVIEW.
And what does error 1772 say ?
Take a picture and paste it here.
02-08-2012 10:03 AM
My OS is Windows XP.
I am trying to install an older LabView run-time engine since my application VitalView asks for a LabView 6.0 Run-time engine (or something compatible).
I have attached the jpg of the error message that I receive whenever I attempt to install the LabView engine.
Thank you so much for your help!
02-08-2012 02:57 PM
Do you have other versions of the run-time engine installed ?
02-09-2012 12:49 PM
Thanks for the tip! I went back and uninstalled any previously downloaded files from National Instruments and the installation for the Run-Time engine 6.0 went off without a hitch!
Thanks again for providing a simple solution to my headache!
Gracias!
02-14-2012 06:07 AM
If you want to have multiple Run time engines on the same PC, you need to install them in the right order.
Start with the oldest engine.
I'm glad to hear that you solved your problem.
Please mark the post that solved your problem as solution, so that others can see that the problem is solved.
