Error -1918 - Save to UFF58
Hello to all,
I am trying to save N channels of FRF in UFF58 format using the VI's SVT UFF58 Open/Write/Close. The VI Write is set to "Complex Spectrum - N Ch", where I supose to link separately the Real part and the Imaginary part of N FRF's. But when I try to run the code, the error 1918 appears:
Error -1918 occurred at SoundVib_UFF58.lvlib:SVT UFF58 Write Spectrum (Complex) (N Ch).vi
Possible reason(s):
Sound & Vibration: This function only operates on phase spectra expressed in radians, degrees, or cycles.
I can't understand what this means, since it is asked to link the real and imaginary part of the FRF and there is no mention to the phase.
I thank you all in advance
Frederico
(2,197 Views)
 Hello freddearaujo
Can you share a printscreen of that code section and how you parameterizing the SVT UTT58 Write?
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
(2,146 Views)
