Error 193 while opening LabView exe
I made an executible using LabView 2017 sp1 64bit on my PC. While deploying on another PC, I first downloaded and setup the LabView 2017 sp1 64bit runtime engine.
First I had issues opening the executible. It could not locate the runtime engine. By reading different discussions, I came to the conclusion that the executible has to be in the same folder as lvrt.dll file.
So I saved my executible in the folder that has the lvrt.dll file. Now I am getting a new error that says "System Error 193 while loading the LabView Run-Time Engine". Picture attached.
Please help!
(4,299 Views)
Hi nmanthalkar,
Why don't you create a full setup (aka installer) for your "COG_System" executable?
It will include and install any needed RTE stuff…
(4,272 Views)
GerdW,
Thanks. Problem solved! Saw an online video on youtube to create an installer.
- Neeraj
(4,222 Views)
