Error -1950679035 When Using the LabVIEW Shared Variable
While communication of PLC & labview 2014 SP1 via modbus ethernet I am getting continuously Error -1950679035 as per attachment.
Also distribution manager system is not responding while expanding of shared variable library. And it is not showing list of variable.
Please share some solution.
(5,781 Views)
If the Distributed System Manager isn't running, then something is seriously wrong!  Has it ever worked?  Have you ever had a successful deployment of Shared Variables?  Have you recently installed a new version or updated LabVIEW?  These questions are designed to see if something "broke", or possibly never worked in the first place ...
Bob Schor
(5,728 Views)
I'm getting the exact same set of problems on a cRIO-9066 running LVRT 14.0.1 and cRIO 14.5 drivers. I opened a support request with NI AE but the tech I'm working with has no idea what's wrong. He even issued me a loaner chassis and I'm still getting both the error and the problems with Distributed System Manager.
(5,637 Views)
(This was a red herring. Sorry.)
(5,608 Views)
