Error - 1950679035
hi guys,
i have a problem, when i run my vi (that includes shared variables) an error occurs named 1950679035. i also check " \National Instruments\Shared\Tagger\tagsrv.exe" and "\windows\system32\lkads.exe".
as you see at the first attachment (named 1) , when i run the vi (with no error) without any connection of the port4. when i add the port 4, this error occurs (second attachment named 2).
does anyone knows what i should do to fix this error?
drycsr
Thanks!
~drycsr~
(12,079 Views)
Have you looked at the possible reasons for that error?
Error -1950679035 occurred at an unidentified location
Possible reason(s):
LabVIEW:  (Hex 0x8BBB0005) Unable to locate variable in the Shared Variable Engine.  Deployment of this variable may have failed.
Check to make sure you actually have the variable deployed.
(12,047 Views)
Hi Drycsr,
I agree with smercurio_fc, it looks like your variables are not deploying correctly for some reason.
Below are some links that might point you to the right direction.
http://digital.ni.com/public.nsf/allkb/A12707C3AA00F5598625737C0066D4F6?OpenDocument
http://forums.ni.com/t5/FieldPoint-Family/Shared-Variable-Read-Error-1950679035/m-p/584832?requireLo...
http://forums.ni.com/t5/FieldPoint-Family/Getting-error-1950679035-despite-lvlib-deployed-without-pr...
Josh L.
(12,004 Views)
Thank you "smercurio_fc" and "Josh L." I'm looking at the links..
Thanks!
~drycsr~
(11,990 Views)
Accepted by topic author drycsr
i solved the problem. right click to "(library name).lvlib" for port 4 in project explorer and select "deploy all"  thank you again!
drycsr
Thanks!
~drycsr~
(11,956 Views)
Dears, I have problems with Shared variable when i access a shared variable alarm properties through property node i encounter the following error.( I am using LV 2010 and DSC 2010 Evel.) Error -1967362032 occurred at property node IAK_ SHARED (Hex 0x8ABC7010)
(11,837 Views)
SSRaza:
Are you reading your alarm properties remotely? You may want to take a look at this KB.
Hope that helps!
Caleb Harris
National Instruments | http://www.ni.com/support
(11,821 Views)
