Error 195067935 occurred at Shared Variable
I cannot use Shared Variables.  I used the same VIs which did run successfully 3 months ago without this problem. An error message is below,
Error -195067935 occurred at Shared Variable
Labview: (Hex 0x8BBB0005) Unable to locate variable. Deployment of this variable may have failed.
I have unblocked LabView in Windows Firewall but that has not fixed the problem.
I got the error every time I run a VI with shared variables and it actually pops up an error message asking me to continue or stop.  According to LabVIEW the shared variables deployed successfully.
Just to make a clear point,
1. Unblocked LabView in Windows Firewall
2. Everything seems to have been deployed
I found a discussion form saying that I need to repair the Shared Variable Engine. I went to Control Panel >>Add/Remove Programs>>National Instruments software to find the Shared Variable Engine but I couldn't find it.
Please let me know how to fix this problem.
Thank you,
(4,939 Views)
Open the Distributed System Manager, and make sure that the variables were deployed and are responding.  You can also refer to this link which explains what can happen if your RT processor is railing.  If neither of these things work, you can always try a repair on LabVIEW in case there is an issue with the shared variable engine, however, before that I would definitely confirm that the variables are deploying.
Brandon Treece
(4,919 Views)
