Error 2: Failed to perform Action
I used the Program > Uninstall to remove all the NI Software from my PC due to a largenumber of issues in the dev encironment.
I then went to reinstall just LabVIEW 2014.  I now get an error: "Error 2: Failed to perform ACtion Liscence Manager Updating OS Compatibility."  The next dialog is "Unknown Error (no details)" and then the install exits.
If I look at Programs and Features, I see that the only NI program installed was the NI Customer Experience Improvement Program (irony...)
One KB Article suggsting installing the NI Update Service, but that failed too.
I have tried registry cleaning and MS Fix It, still no help.
I cant go back to a restore point, since there is a restore point created for each NI software (100+), and by default windows seems to only store the last 20 or so.
I really do not want to reformat since I have other software that is a pain in the butt with liscencing to re-setup.
I have re-downloaded the LV2014 installer from the website twice, no improvement.
Kenny
(4,499 Views)
I would recommend creating a service request to work with an NI Applications Engineer on this issue:
(4,448 Views)
Have you resolved your problem ?
(4,324 Views)
