Error -200010 occurred at DAQmx Read
More info.
If I go into Measurement & Automation Explorer my devices are all there.
If I do a Self-Test I get the 'Success' box: 'The device has passed the self test'.
If I do a Reset Device I also get the 'Success' box: 'The device has been reset successfully'.
But then if I go into a Test Panel in the Finite and Continuous mode nothing happens al all, no signals appear. In the On Demand mode I get the following error:
Error -200474 occurred at Test Panel
Possible Reason(s):
Specified operation did not complete, because the specified timeout expired.
Device:  PXI1Slot3
Any more suggestions?
Cheers,
Sarah
Message 11 of 13
(1,319 Views)
Hi Sarah,
Unfortunately I am unable to replicate the issue here but the error that you are receiving sounds like a driver error. I know you have attempted to repair the DAQmx driver on your host machine but have you actually uninstaller the driver from the host and tried reinstalling? It seems to be a very puzzling issue.
If you could try this and let me know how you get on,
Kindest Regards
YatinM
NIUK & Ireland
Message 12 of 13
(1,308 Views)
Yay, it's working now! 🙂
Un-installed DAQmx 8.3 then reinstalled it again. Also it looks like my first PXI-6133 card is faulty, now I have replaced that too all is well.
Thanks for all your help! Much appreciated.
Sarah
Message 13 of 13
(1,303 Views)
