Error -200016
When I run this VI I get the following error -200016
Possible reason(s):
Onboard device memory underflow. Because of system and/or bus-bandwidth limitations, the driver could not write data to the device fast enough to keep up with the device output rate.
Reduce your sample rate, alter the data transfer method (from interrupts to DMA), use a product with more onboard memory, or reduce the number of programs your computer is executing concurrently.
If anyone could help finding out what is wrong I would be greatful. Thanks
Saul
(3,346 Views)
I could not open the "waveform_Gen_Rev2.vi. I could be that it has some parameters set not set right.
However, is the 5 === samples per buffer ?. probably it is toooooo low
(3,342 Views)
