Error -200022 from PXie 6556 cards
I am running into trouble when running my application to synchronize 3 PXIe 6556 card. How could I fix it?
Error:
ni HSDIO Initiate.vi<ERR> Driver Status (HEX 0xBFFA4014)
Resource requested by this session has already been reserved by a different session.
Property: RefClk.Source
Reserved Value: None
Requested Value: PXI Clock Line
Status: -200022
Thanks for your help.
AnDong
(3,213 Views)
Yes, that is the typical expected behaviour if you do the initializations repedetly in the loop. Move the initialization vi's outside of the loop.
Br,
/Roger
(3,209 Views)
Hi Roger,
If I move them outside of the loop, it have a new error
ni HSDIO Wait Until Done.vi<ERR> Driver Status: (Hex 0xBFFA4008) Maximum time exceeded before the operation completed.
How could I fix it?
Thanks and Best regards,
AnDong
(3,202 Views)
Does your signal generation operation take longer time than what you have specified in the input terminal:
http://zone.ni.com/reference/en-XX/help/370520K-01/hsdioviref/hsdio_wait_done/
Try changing the timeout value and run the code with "Highlight Execution", see where the error occurs.
Br,
/Roger
(3,200 Views)
