Error -200022 using NI-9401 to read inputs and monitor counter
Hi, I get a "Resource requested by this task has already been reserved by a different task." when trying to setup to read some input ports while also monitoring a counter on the same port. How is the best way to configure this setup so I can do both things on the same port module without getting this resource task error? Can someone kindly provide a sample of setting this up?
Thanks...
(2,386 Views)
Could someone please help answer this question.
Thanks.
(2,343 Views)
