Error 20003 LV 7.1
Hi
I am using a USB DAQ 6008 for continuous reading of some voltage values
from a circuit. I configured an AI voltage task for 2 input channels,
one of which was then filtered and the result displayed. Everything
worked fine upto this point. But when I reconfigured the task to
include 2 more input channels (continuous voltage measurement) I began
to get this error message "20003: No: of samples should be >0" at the
filter block... although I have entered a value of 5000 in the no: of
samples/channel attribute of the DAQmx Read VI. Can anyone help me out
with this?
Thanks in advance
AK
(2,367 Views)
Hello AK,
I think it would be easiest for us to help you if you could post the portion of your code that exhibits this behavior.
Laura
(2,355 Views)
