Error -200072, but only if I configure and scale my sensors?
In "reading wtf1.vi"  I get Error -200072.  In "reading wtf 2.vi" I get no error.  The only difference between the two is that I've configured and calibrated the sensors.
Also, I don't get the error when I take readings from within the DAQ Assistant, so I know it can measure properly.  For some reason after I configure the sensors and scales the program reads a conflict.
Any ideas?
(2,353 Views)
Try to delete and reconfigure a new DAQ Assistant. That had happened to me when I add more channels after configuring the DAQ Assistant. I also noticed that there are some changes in the Vex source and the resistance value between the two VIs that you have posted.
Richard.
(2,306 Views)
