Error-200077 DAQmx start trigger analog window
I just wanted to setup the DAQmx Start Trigger.vi using the analog window, but I get Error-200077.
Why do I get this error?
(When you run the vi attachec, you must use controls to selectd physical channels.)
Fred
*Kudos are appreciated.*
(4,049 Views)
What exactly are you trying to do over here? And, what hardware are you using? I would recommend having a look at the shipped DAQmx examples provide in LabVIEW (Help -> Find Examples). Also, you need to use the DAQmx Clear Task.vi after you are done with executing the task.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,043 Views)
For the vi attached previously, I was using a virtual DAQ device.  I created the device using MAX.  What I really want to do is use an analog input line like a digital input line (i.e. if the analog input is above 2.2V then set a variable to 1, and if the analog input is less than 0.8V then set the variable to 0.)
Fred
(4,035 Views)
You will need to software time the acquisition since I don't see the benefit of hardware timing it. Attached is a solution (replace the boolean with the number constant).
Adnan Zafar
(4,029 Views)
Thanks, that will work for the problem I mentioned.  I should have mentioned that time is critical in my case.  I was trying to use the "analog window" of the DAQmx Start Trigger.vi b/c I was hoping it would be fast.
This is just a portion of the code for the project.  This task we've been discussing needs to be done (along w/ some other tasks) in a timed loop executing at 1kHz.  I will try to see what results I can get by modifying the code.
Is there a reason you chose to include a 50ms wait?
Fred
(4,025 Views)
Well, but why would you use the start trigger if you wanted to acquire the data continuously from the beginning. That's something I didn't understand.
The application should be able to work at 1Khz since you are using the DAQmx API to acquire only a single point.
No, there is no reason for the 50ms wait. You can choose whatever wait you want.
Adnan Zafar
(4,019 Views)
