Error 200077 strain gauge
Sirs,
I am work on strain gauge matters measurements using a strain 120 Ohm connected to the NI9944 to build the quarter bridge that goes inside the 9237.
I am using:
NI cDAQ 9178
NI 9273
NI 9944
Labview 9.0
I am using the same program that is given in here :  https://decibel.ni.com/content/docs/DOC-11148 with internal excitation 2.5 V, gauge factor 2 (default).
internal shunt resistance 100 kohms; shunt location R3 (default setting). Have selected "Do offset null" and "Do shunt cal"
Error -200077 occurred at DAQmx Perform Shunt Calibration
(Strain).vi:1 Possible reason(s):
Measurements: Requested value is not a supported value for
this property.
 Property: AI.Bridge.ShuntCal.GainAdjust
You Have Requested: -61.980405e3
Valid Values Begin with: 500.0e-3
Valid Values End with: 1.500000
If "Do shunt cal" green button not selected, no error.
Also If i use DAQ Assistance which work just fine with the calibration for the same connection of strain gauge , Ni9237, 9945.
Any ideas?
Please help me out here.
(2,728 Views)
@shivp wrote:
Sirs,
I am using:
NI cDAQ 9178
NI 9273
NI 9944
Labview 9.0
this property.
Any ideas?
Negative number?
Ben
(2,719 Views)
Ben
yes it's give negative number with error.
some time it also give positive number here.
I have also attached the pic of an error here.
plz help me out here.
thank you
(2,713 Views)
