Error -200124 occurred at DAQmx Control Task.vi:3900002
i have a problem with simultaneous read and write digital input/output witch NI 9401 Module.
The following error is occuring:
Error -200125 occurred at DAQmx Control Task.vi:3900003
Possible reason(s):
Lines 4 through 7 of this port are configured for output. Cannot configure these lines for input at this time.
Device: cDAQ1Mod1
Digital Port: 0
Task Name: IGN_READ
On this forum and in Labview Help i didn't find another similar problem or example able to help me.
You can find the attachment to view the vi file.
Thanks in advance
(2,871 Views)
Hi dzanella,
Possible reason(s):
Device: cDAQ1Mod1
Digital Port: 0
Task Name: IGN_READ
The error description is quite clear: you cannot read from DO channels…
No, not yet…
(2,861 Views)
thanks for your respond, but even if i change to digital input the same error occur.
Now would be there the attachment
(2,831 Views)
Hi dzanella,
did you read the datasheet of the NI9401 (carefully)?
It only allows to set input/output in 2 groups of 4 channels per group! Right on the first page it says:
The eight DIO channels are grouped in two ports that you can configure independently for input or output.
You are trying to use
  • channels 0:2 as output
  • channels 3:4 as output
  • channels 5:6 as input, but configured them as output…
So there are two failures:
  1. defining channels as output, but trying to read from them!
  2. defining channels 3+4 as output, but trying to configure channels 5+6 as input: this will not work because you try to use different settings (in/out) within the same port of channels 4:7!
More problems:
  • Why are you creating channels using DAQmxCreateChannels, but then not using that task reference? Instead you use tasks defined in MAX, which are not available to us…
  • Why do you use "one channel for all lines" setting, when you use boolean arrays later on to set your output channels?
(2,824 Views)
Sorry for the late response, i resolve the problem about the channels.
I use "one channels for al the lines" because i saw it in some example and in that way the program works, then I don't undestand what you mean about using task reference in my case
(2,784 Views)
Hi dzanella,
This:
We don't know these DAQmx task references…
How did you do that? This forum works best, when you provide the solution to your problem…
(2,780 Views)
In IGN, FlameDet and IGN_READ tasks, i've just define the pins i use as input or output. Nothing else. Again, in that way the program works but i put this tasks when channles problem persisted so i don't know if i do in another way the program would work anyway
(2,767 Views)
