Error -200213 occurred at DAQmx Start Task.vi:
Good day,
I am trying to use the example I got from the NI web about digitalStartandStopTrigger.vi without any modification but it keeps on giving me the Error -200213 occurred at DAQmx Start Task.vi:5.
Please any help is more than welcome.
Stephanie
(4,335 Views)
Hi Stephanie,
When I looked up that error, I found the following information:
What have you specified for the number of pretrigger samples, posttrigger samples, and samples per channel?
d
(4,326 Views)
I get the same error. I don't know how to solve it...
(3,894 Views)
Have you tried the suggestions? You haven't posted your code so it's impossible to say how you have incorrectly configured your task.
(3,886 Views)
yes I did.. I tried changing the number of samples per channels and also number of pretrigger samples... did not work!!!!
here is a picture of my Vi. hope it helps...
 it's really simple:
the first line is generating a signal, the second line is the trigger for the last line which is acquiring data.
about the trigger property node.. I have no idea.. I just found it somewhere and used it.
the vi worked before but I have bought a new device and its not working anymore. new device is S series...
(3,877 Views)
