Error -200220 occurred at DAQmx Create Channel (CI-Count Edges).vi:1
I get the following error when running my VI, says device identifier is invalid (ERROR -200220) and I was wondering how to fix this..
(5,818 Views)
this keeps repeating for others such as AO Voltage and I have to end task to shut down labview.
(5,817 Views)
would it be that my chasis is unidentified? Im confused as to which to choose? Im using NI cDAQ-9172
(5,810 Views)
Hi there,
It sounds like this might just be an issue with using the wrong device name for your cDAQ module. Make sure that you are using the same alias name that you have configured in MAX for your device. This KnowledgeBase might
help you: Why do I Receive Error Code -200220 When Running a Data Acquisition Program?
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(5,779 Views)
also get -200099 error codes after this
(5,765 Views)
You get this error after doing what exactly?
Efrain G.
(5,752 Views)
fter trying to run my labview VI...I have to task manager as the errors keep projecting
(5,734 Views)
