Error -200279 occurred at preizkusevalisce 1.0.vi:Instance:1:490001
this error appears soon after I run the program:
Possible reason(s):
The application is not able to keep up with the hardware acquisition.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Corresponding Value: 0
Task Name: _unnamedTask<39D4>"
The program works perfect before, but then I did not using it for one year and this problem appears. I am using LabView 2020 and ni usb 6009.
(841 Views)
(800 Views)
